I took some logs of the street races and i am pretty embaressed to say that i totally botched the race with that torana... i stuffed up hardcore. :)
I got some data together, i did forget to set the ecu to log SPEED as well :blink: so i got the data that was logged and set it up into a excel spread sheet.
You can see that the stupid anti lag did not spool as fast for some reason, i think i was too slow on the throttle and i dropped the clutch at 3100rpm when racing that Torana Drag car compared to when i raced the Datto 1200 ute i dropped it at 6100rpm+.
So yeah here is the screen shot and the xl spreadsheet if anyone is interested in checking it out. I cannot say that i would have beaten the Torana if i launched properly because its best quarter is a 8.7 second quarter mile but I can say things may have been different. I guess its all a big learning curve and i know now what NOT to do next time.
Anyways if anyone can give me some ideas on where i stuffed up or whatever then go for it.. I can take constructive critisism.
I converted the boost levels every now and then from KPA to PSI so you guys understand the boost levels i was running, over 30psi!! - 2 bar of boost.
Metric Converter is here, put the boost kpa in my log into absolute KPA to get the PSI
http://skylinecentral.org/upload/MetricCalc.exe
Excel Spreadsheet
http://skylinecentral.org/upload/race.xls
And just to comment on the data..... even though you botched the drag car run with the antilag , its obviously alot smoother.... whereas your having to be on /off throttle alot more with the ute run.....
So maybe you need to try a lower rpm limit to reduce crazy wheelspin on launch for when it does boost up properly ? Obviously wheelspin is always going to be there with your power, but the drag car runs shows higher boost and more consistent, so if you can get this with the more instant responce of the dato run......
This is on pump fuel too isnt it ??
Gary
Edited by Fastrotor
yeah.. thats the one.. its a 8 second drag car with wheelie bars and chute!
it would not have looked so bad if i did not stuff up the start but you get that :banana:
You do know that this Torana won ?
when you ramp near 30 psi your afrs plummet to low 10s
is this by design as part of a safety catch?
your probably sacrificing power / throughput to cram more boost in safely - ie there might be no gain from this, or it could be negative gain
you might find more power / throughput from less boost and mid 12.5 afr instead
Yeah I like to run my engine rich. Especially for power cruise I was expecting it to get hot and I wanted to keep the temps down as much as i could so I tuned it this way.
I never tune my car to 12.5. I would rather sacrifice 10kw and have heaps of extra cooling there then have a tune on the edge which will detonate when the air temps get up there..
The car ran hard all weekend, 3 days worth of thrashing the crap out of it and the engine did not miss a beat! Yes i did go through a full tank of fuel in 190km's worth of track time in ONE day but i had damn good fun doing it.
I normally run 11.3 - 11.5afr on cars I tune with a fair amount of power. Its just safer that way, my 10afr stunt was just something I did for my car because the weather was a bit up there on the sat and sunday.
This was tuned on BP98 and was running on Shell optimax half the time at power cruise.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
