I get my car back tomorrow (for hopefully the last time!). Phillip Island this weekend as a final shake-down. Looks like we might even get a bit of wet down there which could make for some great Targa practise. :D
Should start to get excited then - although I reckon I'll have another distraction for a couple of days this week at least.
But I know Drew and Georgie are heading over to Tassie this coming weekend for Recce.
  • Replies 652
Posted Images
This is delivery week Andrew? Great stuff mate :D
I think Scotty should have his in time for Targa recce too. I'd hate for my recce car to be faster than my race car. LOL (him, not you)
Yeh lol didn't think of that!
Actually from the play I had in Jeff's a while back I think it might be faster than my race car as well especially since we've turned the R34 down so much recently (And yes I'm bringing the R35 across as my recce car!)
Jeeze Snowy may aswell bring the whole fleet across... R34, R35 and heck bring the R36 for good measure :D
Haha - I'd like to have done but the wife didn't want to come. Something to do with "blah blah blah" (aka - I wasn't listening to her excuses as to why she didn't want to come. It was unimportant.)
But - I'll be taking pics of the 3 of them together this weekend. I'll be sure to post them up for you all :D
haha, I was gunning for 832... then realised 732 was it when I woke up from my dream and realised i wasn't in a GTR :down:
See your sig has changed and appears fluid. You are definitely giving Deano Value for money... DOnt forget that art mob that is throwing bucket loads into your racing.
And just so Rocket can see the history in the Camera Car
Some Nostalgia - Click Here
TT984
Once custodian of 832 :bunny:
