I get my car back tomorrow (for hopefully the last time!). Phillip Island this weekend as a final shake-down. Looks like we might even get a bit of wet down there which could make for some great Targa practise. :D
Should start to get excited then - although I reckon I'll have another distraction for a couple of days this week at least.
But I know Drew and Georgie are heading over to Tassie this coming weekend for Recce.
  • Replies 652
Posted Images
This is delivery week Andrew? Great stuff mate :D
I think Scotty should have his in time for Targa recce too. I'd hate for my recce car to be faster than my race car. LOL (him, not you)
Yeh lol didn't think of that!
Actually from the play I had in Jeff's a while back I think it might be faster than my race car as well especially since we've turned the R34 down so much recently (And yes I'm bringing the R35 across as my recce car!)
Jeeze Snowy may aswell bring the whole fleet across... R34, R35 and heck bring the R36 for good measure :D
Haha - I'd like to have done but the wife didn't want to come. Something to do with "blah blah blah" (aka - I wasn't listening to her excuses as to why she didn't want to come. It was unimportant.)
But - I'll be taking pics of the 3 of them together this weekend. I'll be sure to post them up for you all :D
haha, I was gunning for 832... then realised 732 was it when I woke up from my dream and realised i wasn't in a GTR :down:
See your sig has changed and appears fluid. You are definitely giving Deano Value for money... DOnt forget that art mob that is throwing bucket loads into your racing.
And just so Rocket can see the history in the Camera Car
Some Nostalgia - Click Here
TT984
Once custodian of 832 :bunny:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
