  • Replies 652
Posted Images
I fail to see what was wrong with the old one? I'm pretty sure every track GT-R diffuser I've ever seen looks like that! :P
it's fine appart from the corner that is broken off where a bank hit it (i put it back together for the photo)
roy: it's for the front.
Geez Snowy, like I said in the other thread mate, congrats on your new GTR!
Although I cannot compete with the Shock and Awe of a 34/35 recce/rally duo, we can always have a little fun :)
The stickers finally done by 1am tthis morning, we modded the Signal stripe a bit from the original at the leading edge, it looked a little too much like a willy for my liking. Just needs the Shannnons for the windscreen and the door panels now :P
Once I have it running again I'll grab some better pics of it outside. These pics are of it not quite finished as I was dead on my feet in the later stages.
Ahh the joys of living in Tasmania now.
I can go and check out all the Targa cars!
Look forward to seeing some of these cars in the flesh!
Yeh mate come along for a look! and drag that cousin of yours up, i haven't seen him in nearly 2 years!!!
That's either a random 'everyone in Tasmania is related' joke, or you actually know my cousin Nathan?
Edited by Cyph-R33
yes I know Nathan, have known him (and his antics) for a long time :D
Car looks great Ben, nice job!
Yours too Snowy, that's quite the duo.
And the bonus being my name got spelt right, doesn't happen too often!
Kel - is that Friday 24th? If so Drew/Georgie and I are all on that boat too.
Yep - the 24th it is, looks like we'll be sailing mates :P
I think we're also booked back on the Monday with most of the other Targa traffic- always a fun trip with lots of beer and bullshit!
btw for any navis lurking on this thread (who aren't facebook friendly).
Mozza has passed this on to the Rallying Nav's & Co-Drivers of Australia group on facespace...
Peter Leimuss requires a Nav/co driver for the lefthand seat of his R35 GTR SKyline, please conact Helen Coad at the TARGA TAS office to book your seat,
EXPERIENCE IS VERY NECESSARY,Vandenberg pace notes, and weight is an advantage (or lack of!) !!!!! Flights, accom etc provided
Having done 2 rallies with Pete I can definitely vouch for his driving :P
I am surprised he doesn't have a nav already!
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
