  • Replies 156
Posted Images
OMG my sump crashed into a big ally box with blue bits on it.
I can see me at super cheap from now on.....
"Hi I need some cheap oil for an oil change. 3 bottles of whatever is on special...
"What, 1litre bottles?
"No, 5 each, Brad promised I'd never kill another bearing this way
That's a challenge I really trhink I am up to :(
hey evil chris.....in 10 days.....thus the rush! Oran Park last weekend of May. Wathc out dinosairs
yous drunker than me. I can still type coheirantly when i need too.
There's fancy shit inside it too!
I measured it and you will need 3 bottles of the finest. thats a pretty expensive oil change but still cheaper than a rebuild. Actually it costs me less to buy bearings than it does to buy oil now I think about it!
Still a bottle or two short of my tank!!
If you do another bearing Im dry sumping it and shoving the oil pump up Guss' arse!
There is nothing else we can do about oil control using this stupid pump layout.
Myt welds on that sump are actually pretty straight, needed another crownie before I welded it.
Indeed - no other GTRs entering this round? :blink:
Looks like my chances of getting there are better - but still could be impacted on stuff beyond everyone's control. The motor is in the car and will be running with a couple of hours work - then she just needs a run in, check the tune and it's right to go. Fingers crossed.
haha, that's be the day to attend!
His new donk should survive, or it friggin well better cause we don't have the spare built yet.
Sam spent ages checking and double checking then I spent ages checking again before it was assembled.
Duncan seems pretty happy with the sump and external pick up arrangement. The sump only JUST fits inside the sway bar and chassis rails. It held just shy of 14 litres from dry!
good stuff jay. and brad for providing the location :( still a lot to get it ready for the weekend but at least shes running.
Chris - its qual and race 1 on sat, or 2 races on sunday. sunday is probably a better day to watch.
well actually, if you wanted to see my car run.....waiting until sat was too late.
oil supply issue to the head led to a snapped cam while running it in - so I've gone from just making this round to missing it by a mile :D
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
