Which one should i print?
10 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
EDIT: im going to make this into a pole
Which photo should i print?? Either in canvas or gloss style (poster). Please note the poster will be framed properly too if i go down that path :D
Oh and please do recommend me some places to get it printed.
Why am i doing this??
Well i would like to remember my europe trip for rest of my life and what better way to print a nice photo.
Hi,
I would like to print the photo below onto a large gloss sheet or canvas.
Can anyone recommend me any places? Hopefully they are located in Sydney. If not an online shop perhaps??
Should i print onto canvas or gloss sheet?? I know with canvas the print will be a little rough (well i mean you can see lines - if that makes sense?)
Also i wouldn't need to frame the canvas (save some money there).. But the gloss sheet would look better right?? esp when its all framed nicely!!
What do you all think?
Im leaning more towards number 1.. hmmm
1.
2.
3.
4.
5.
6.
7.
I think if you want a picture to remind you of a holiday you are the best person to choose which photo that is
since they would all remind you of something different and some might be better than others for that
Personally I like the first one the best (but it does not necessary scream Europe - not for me anyway)
I've done a few canvas prints, and I wouldn't recommend you print any of them on canvas, anything that is dark or has a lot of shadow doesn't look good.
If you want to get a proper print + top quality frame, then look at uploading the picture to redbubble and buying getting them to do it. it's around $140 (I think, cant get to the site from work) for a huge frame and top notch print, if you are unhappy with the print for any reason then you can contact them and organise a reprint as well. I havent had to do that for the 3 i've got printed there though.
True does not scream Europe..I'm leaning towards number 1 as well. Perhaps i might just print it on a small scale (a4 perhaps) and see how it looks. Instead of wasting big money on larger prints.
Thanks for that slim. Much appreciated. Will check them out :banana:
Which photos of yours did you print out? Just curious..
number 3, if you have it in colour. the rest look like postcards. not something i'd hang on my wall.
yea my sis likes number 3 as well.. ta
Edited by siddr20
WOOT i received pic number 1 today :verymad:
It was beautifully framed in a flat black frame with bright white border.
Looks stunning :wub:
The sky esp with a slight purple tinge really shines. Looks so beautiful!!
Will try and take a pic tonight and post it up!!
For those who are keen to purchase let me know.
Cost will be $180 plus postage (this is for the largest size - 610mm by 406mm).
Cost will be less for smaller sizes offcourse :O
I will chuck all the details in the for sale section :)
Frames are crafted from quality timbers in a range of finishes. A white, off-white or black matte surrounds the print to emphasize the artist’s work and bring the piece to life. Premium ultra-clear perspex in front provides a superior finish and means the piece is lighter and easier for you to move without breaking.
Check pic below for different options:
Edited by siddr20
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
