a massive 'big up' to the other SAU'ers out tjere, Ian, his mate micheal and Mark!!
awesome effort all of them getting into the 47-48's!! glad everyone had a blast!!
  • Replies 159
Great day and a really great track...will def be headin down there again.
Sorry we lost you guys on way home, we pulled into the wrong servo dumb
oh....and i dont wanna see photos of my car.....going round corners at 45 degrees....damn suspension
Oh so the laps are timed and everything!? Sounded like a massively fun day, please let us know when the next $50 one is on!!! I'll be there.
Stolen Borrowed from the Supra Forum
1 with the poor 34 in it, and 1 with a little red beast(evil weevil) and a little white beast(too_ much_ boost) on the gas, I had to blow it up to 300% to see though.
Yes, Lou had a moment in his 34 but we managed to get him back on the road after spending most of the afternoon under the car for him as he didnt have any real mechanical aptitude.
After all the mucking around and we rebuilt his intercooler and front end with race tape and had him driving home, we got a call from him saying that he had blown another tyre on the way home and he didnt have a spare.
Given that a towy wanted $600 to come pic him up... Anthony one of Autosports regulars pulled over and lent him one of his semi's to get him home. Poor Lou couldnt turn a trick!
Hopefully we will see Lou at the next Autosports event at Wakefield Park on 9th May
that event above is infact the Wakefield Park event. The next Marulan event will be announced in the next week or so... still not sure about prices but i can assure you it wont ever be $50 again. That was a promo for the new facilities in which Autosports was happy to promote for them
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
