Brand new Nismo R34GTT front sway bar
$420 del
Reason for sale: Wont fit on my R34 GT-4 as i need a BNR34 one :P
Also Bosch 870cc injectors to suit R34 GTT. Bolt straight in but u need to run a positive and negative wire to the injectors from the existing connection (5min job) 3000k's old. Look stock.
$720 del
thanks Luke
Do you mean there are no plugs?
They got a plug which you plug into the injector and off that plug is 2wires (positive/negative). So you just wire up those from your existing connection.
If your serious PM me with your offer.
im sure the GTT it came out off had a modified rail, im 100% sure theyre the same shape as GTR ones as the GTT ones are skinner.
not trying to kill a sale but just letting ppl know before they jump on it.
gl with it mate.
http://www.skylinesaustralia.com/forums/R3...40-t110794.html
The blue stock injectors are indeed skinnier, but comparing the dephi injectors in that thread to your Bosch injectors, they look to be very similar in design and physical size.
Hope that helps.
Sway bar $400 pick up
Not sure about that Impedance stuff. Basically took them out of the car, bolted the old ones in and connected them up.
thanks Luke
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
