It sounds to me like a great car
as I said to buster to build a car up like that would cost a fortune the turbo's alone are worth a packet.
I personlly would prefer an r33 with a rb26 than a gtr why?
because it would hammer. I have been in a couple of very hard core r33's and r32's and they are wicked.
a gtr is nice but hey lots of peple own gtr's.
and the motors pretty well bolt in.
yummy
meggala
Originally posted by Boxcar Racer
mmhmm they bolt in, if i had the cash, i would put an rb26dett in my car, then i wouldnt clean it, or fix the damage, would look veyr very stock, and every man and his dog would race and loose.
lol
Tank :P
Then work it
700RWHP :):D:DD
