  • Replies 94
Posted Images
  • 1 month later...
You know, if you go to the K&N website, it says you can order a CAI kit from Repco or Autobarn. So why bother searching high and low for a kit (or even DIY)? I am not in Aust now, but it will be the 1st thing I'll be doing - to enquire about the price at Repco.
Or, another alternative, (If you are a cheapskate like me), then search eBay for a kit. The best kit that i have seen so far with a K&N filter is $58USD plus $55AUD delivery. It's $20.50USD for a kit without the K&N pod filter (I wouldn't recommend) from the same USA Seller.
Hope that helps.
And oh, despite what you read on the K&N website regarding V35 sedans (G35 Infiniti) and V35 Coupes, the CAI is the same, except for the coupe CAI Kit, they have extended the pipe further down into the front bonnet area. Anyways, do your own research.
Furthermore to this, if you are searching for the radiator air dam cooling plate thingy , don't be silly and go a 350Z one as it won't fit! And, coupes and sedans differ, so buy carefully. I have also searched ebay and found a good CF one for around $50USD to fit the coupe (and needs a bit of trimming to fit the sedan).
For all you V35 coupe owners out there, feel lucky that you can get much more aftermarket bling bling than us poor V35 sedan owners....
My 2 cents worth...
K&N Typhoon cold air intake is about $700 give or take 100. Got one for my Camry last year.
AND i just finished putting on my new cold intake...... oooo
I had a "Panic Attack" when taking off part of the intake pipe :D . It ripped almost in half "OMG!!" have to fix this so i can drive me car!
Got it all fixed with glue and tape, lots of tape. :P
Started putting in the new intake and blow me down i didn't need the part i broke. So the trip to the local supermarket to get the really cheap glue and tape was a waste of time so was all the yelling i did at myself.
Pics
Looks good ay?
yup, JWT.. i m still deciding if i should keep my cf tube in or swap it with the z-tube and which to sell..
Paul, how did u get the heat shield installed? i still cant figure out how to put tat into the car :)
LOL yeah took me ages to work it out. but when i got it in i was like "oh how easy"
At work now, i'll post a "how to" with pics when i get home
the whole process was a little scary.. *doing these first time..
After failing and the sky getting dark, i gave up and drive without it, normal.. (mayb vic is too cold to feel the difference)
When the car is started, i do feel the air heat blown from engine if i put my hand under the pod, so better get the shield installed soon.. to block it from sucking hot air..
Did u hear the little hissing noise when u giv it a big push? i hv... still trying to find out if it 'suppose to b' tat way or there is a small leak..
Not really any hissing noise from mine. i do get a little half second hiss when i first tap the go peddle.
Well you are ment to put on the heat sheild before anything else but i guess you can work around the pod.
It's only there to stop the heat from your engine. But i guess if it's a cold day and your driving, the cold air would blow the heat away "maybe"
Just had my V on the DYNO again but the readings were not good. Ownly because the V's need time to adjust to the new settings. I had a before test from a month ago 163kw on the wheels then put my spacer on and got 170kw, put the new intake on and got 153kw on the first go :D"WHAT IS GOING ON?" second run 163kw, next 168kw, next 171kw, next 174kw, next 178kw, then i stopped it was getting late. So the V needed time to adjust. I will go back to the DYNO next week after the car has had more time to adjust.
The sound is wicked cool. I still got my standed exhust (i don't want to change it)
hey dude looks awesome how is the sound! i want to get a JWT but have heard it actually lowers power / does nothing because it sucks in hot air from the engine even with the pod cover.
i was thinking of getting the stillen, which is enclosed in a box, hence it will be harder to get defected for also. i have also read the stillen actually does lower intake temps because of its design.
well in the end i got more power but still going to wait until the V has adjusted. I was getting cold air in the pod. we had a temp sensor in the pod. It did lower power the fist run but got better as we dit more runs.
Didn't you read my last post?
wanna ask for some suggestion.. i heard somewhere that the oem 350z intake pipe is actually better, compared to stainless steel pipe, due to reason that stainless-steel pipe gets hotter easier and faster than plastic, so actually hot air are being suxked in..
Anyone can help to explain if this is right or wrong in anyway?
I do kinda agree if someone told me plastic gets hot the same way just like stainless steel... but it does also get colder faster than plastic rite?
this is the reason i still cant decide wat kind of intake i should buy and install on my v35.. :D
Why not get this Intake Induction Hose 4PLY Silicone.
It should be even better in Heat resistance. You can find it in Ebay
ok all....
intake pipe with K&N pod filter on ebay:
Item: 370192426273, $58USD plus $55USD shipping and $2USD insurance....
I just ordered my kit...
Edited by siu_loong_bao
ok all....
that is sooo cheap. Hope it works out.
Keep us informed
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
