yeah i got a copy of it to =] sound isnt great but it does the job and quality is quite good specially for a cam
i still went and saw it at the movies last night though =] always better on a V-MAX screen
  • Replies 70
Would be great to see a Supra. We need more Toyotas :( Only got a few MR2s coming. It's mainly skylines and FTOs.
Roof carpark near the cinemas. 7.15. See you there :O
>_< oh mann i rocked up late, had trouble finding the upper level...lol dont ask..i went to 2 different top floor carparks n none were the right one. eventually found it tho, wish i had that map..
All the skylines looked good lined up together, n the mr2s, (my step dad has a mr2 spyda -goes good ) wish i had my 33 there to get some shots.
Didnt get to really meet anyone though just talked to Kris for a bit then i headed off..
meet all you guys one day =]
someone organize another meet so we can get some shots =]
We'll be organising another meet really soon so stay tuned :bunny: We'll do a day time one so we can get some decent pics!
As for MR2 Spyders... :banana: No comment.
Gotta have the SW20 MR2s - they actually came out in turbo! :bunny:
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
