  • Replies 47
a r33 gtst will get s14 and a s15 , is the 300zx turbo? the 180sx s/2 has the same motor as the 200sx as the new one, i had a 97 180sx they are qucker than r32, i think they go good as wrx,s. i had a race with a 200sx the new one in a r33 gtst and it had a big front mount and i beat it by 3 car leanth we raced up 2 about 120km
not to be bias but i say the s14/s15 should beat the r33 (from past experience). Not sure about the 300zx though. R33's are heavier than the s14/s15 and between the s14 and s15, the s15 should win due to a ball bearing turbo, lighter body and better diff. A friend of mine has a stocky 180sx and that used to beat my s14 when stock and another friend's stocky r33 too. But im sure that 180's shouldnt be THAT quick normally, just that his happens to be a bit of a freak. :)
Does it really matter? They can each be modded off their tits to beat any of the others, just depending on how much money you want to throw at it.
That's why I bought the car that I like best for reasons other than how fast it is down the 1/4 mile. And the mods that it came with made it faster than any of the aforementioned when stock. So in theory I got the best of both worlds :P
:werd:
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
