Hey Guys,
Before everbody tells me to use the search function I can assure you that I have looked and then looked again so here goes.
I bought a HKS adjustable actuator through one of the traders on these forums and I asked how to set the boost levels for my new High-Flow (Want to keep it on 10psi for run in) and he instructed me as follows- "The longer the bar the harder the spring pressure the shorter the bar the softer, less boost pressure. "
Now I have also come across a pdf whilst doing a search and it states as below
"You will need to pre set the boost you want.
128mm = .5Bar or 7.25psi
123mm = .8Bar or 11.60psi
121mm = 1.0Bar or 14.50psi
119mm = 1.2Bar or 17.4psi"
Can someone please confirm which one is correct I dont want to set what I think is 10psi only to have it 30!!
Thanks
https://www.sau.com.au/forums/topic/260359-need-help-to-setup-hks-actuator/
Hey Guys,
Thanks
You shorten the rod to increase boost.
"most" common is to have the rod hole missing the actuator by the thickness of the rod it goes onto.... ie you have to stretch it the thickness of the wastegate flap pivot to get the actuator to go onto the flap... make sense?
Umm not really so I go with the advice on the PDF? Maybe it's a little early in the morning...or I'm just stupid(probably both!)
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
