this is more an expression of interest, there is nothing wrong with the 31, i just found something else i'm interested in...
1989 Passage GT
Recently built RB25DET Conversion
Polished and ported head
RB25 gearbox with short shift
Tomei technical trax 2way diff (Brand new and unused, stock diff is currently in car)
600x300x76 FMIC and piping
KKR480 Turbo (currently tuned for 15psi, seals replaced)
Koni adjustable sports suspension
R33 4 pot front calipers with slotted rotors
R33 2 pot rear calipers with slotted rotors
Power FC + hand controller
PWR alloy radiator
twin bucket seats
Sparco hyper fang II 17x9" all (will have new 235/40R17's all round)
3" turbo back exhaust (loud, but very nice note, have a few 3" mufflers i will either have installed or throw in)
Z32 AFM
750cc powerflow injectors (BRAND new, cleaned and flow tested in the last week)
RB26 coil packs
700hp fuel pump
Gates timing belt
clear indicators coming, and all stickers removed from outside car.
auto spoiler (front lip)
ADThree R30 rear lip
boost, oil pressure, oil temp, coolant temp gauges
EBC with high/low boost switch
mp3 deck, splits front and rear, sub + amps the usual shiz.
probably a few other bits and pieces i have missed...
car has just had a full check over trying to diagnose a missfire (failed injector), including compression and leakdown tests with good results.
interior/exterior is in fantastic condition for a 20 year old car, not one rip or tear.
chasing $17,000
https://www.sau.com.au/forums/topic/260573-rb25-powered-hr31/
  • 2 months later...
this is definately for sale now... make me an offer!
there is literally not many things left on the car that are factory now, 99% of the engine bay is brand new or aftermarket parts, brand new 235's all round.
  • 2 months later...
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
