will be close/borderline to being maxed.
if you were under i would say ok, if you want a solid 300+ then maybe get a 044 bosch motorsport pump, good for >400rwkw.
see how it goes, if it leans out even with extra injector duty cycle, will need to upgrade.
https://www.sau.com.au/forums/topic/260658-gtr-fuel-pump/#findComment-4471741
Well Snowman ran a stock R34 GTR pump i believe with 350rwkw
Really depends on the pump, age, and so on.
Only way is to either get the tune and go off how the AFR's, fuel pressure looks... of flow test it. Although flow test @ normal flow might not show up something that wouldnt otherwise show up until pressure rises
https://www.sau.com.au/forums/topic/260658-gtr-fuel-pump/#findComment-4471787
Yeah stress an old part - why not, fuel isnt important.... :)
Bosch pumps are cheap, unless you are saving every penny just get one, then you wont have to worry :(
^^ 100% Agreed - why not just upgrade it now?
They arent super expensive and at least it gives peace of mind it will handle anything you throw at it... a few $$ spent now could save alot more $$ spent sooner than expected.
https://www.sau.com.au/forums/topic/260658-gtr-fuel-pump/#findComment-4473167
l made a post regurading the same question a few months back. lets just say l was mocked by some dicks on this site even thinking of pushing that much power through a GTR fuel pump. Now l know l am not the only one who has a GTR fuel pump pushing beyond the 300RWKW mark, makes me feel a little more content with my current setup.
https://www.sau.com.au/forums/topic/260658-gtr-fuel-pump/#findComment-4474534
If the pump has only done 40,000 as an example it should be fine.
When it fails, replace it ;)
Stock turbos are more of a danger than the fuel pump.
And hell, its not like Bosch pumps never fail even 1,000kms outta the box! Everything has some risk...
https://www.sau.com.au/forums/topic/260658-gtr-fuel-pump/#findComment-4474643
Ive got a stock R34 GTR pump in my car made 285kw with no signs of it even being near maxed :blink:
cheaper than an 044 to ;)
Hey I'm in the camp of people that would rather not take the risk, and am looking to upgrade.
However, after reading the FAQ/tutorial thing about the bosch 044, it is clear that it is far from a bolt-on upgrade. I have been looking at an alternative that will just "drop in" to the existing in-tank cradle setup (I would rather pay the extra and not worry about the hassle of modifying things or worrying about the hose etc)
So far I have identified the nismo pump, which is about $440 plus post; also there is a sard item sold by JJR that is $700 or something, allegedly that bolts in. My question is:
1) can someone confirm the nismo item is a bolt in, no mods required (r32?) What about the sard?
2) are there any others that are better priced and drop into the existing cradle?
https://www.sau.com.au/forums/topic/260658-gtr-fuel-pump/#findComment-4476401
Go the Nismo/Tomei drop in pump.
Its the easiest, most reliable pump replacement option.
https://www.sau.com.au/forums/topic/260658-gtr-fuel-pump/#findComment-4476899
just dont run e85 or your new nismo pump will die a ugly death....
and maybe your engine as well
LOL yeah, I didn't drop $ ,000's and $ ,000 on turbos, intercooler, drumps, zorst to attempt to save 5c a litre on dodgy petrol and get 30 pc worse mileage! I just run it on vortex 98, seems pretty happy.
Seriously, guys, thanks for the help, I was about the buy the bosch until I read the write up and was like "um, not for me thanks" so will go the nismo (had heard of the tomei but didn't realise it was the same thing?)
Cheers
Andrew
https://www.sau.com.au/forums/topic/260658-gtr-fuel-pump/#findComment-4477445
GTR pump in good condition is ample for 300 or even 350rwkw. but if there is a cloud over it's reliability (ie old R32 pump) then it can be worth replacing. I've had one fail before at 270rwkw. it didn't cause any damage when it failed but it was a pain in the arse. bosch pumps are ok, but the nismo/tomei pumps have been the most reliable in my experience but they may be just because they are a true direct fit pump where as a lot of the bosch pumps fail due to incorrect installation. you eliminate any chance of that with a nismo/tomei pump. you would have to try really hard to fk up an install of one of those.
https://www.sau.com.au/forums/topic/260658-gtr-fuel-pump/#findComment-4480196
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
