Hey Guys,
I'm getting my motor rebuilt at the moment and thought it would be a good idea to have to engine covers resprayed while its all off in pieces,
as the covers were starting to look a bit dull.
I want to get them painted same colour as the 34 NUR engine (pic below)
I've done a search through the paint codes, but can't find the one which applies.
Please help!
https://www.sau.com.au/forums/topic/260881-rb26-engine-covers/
Hey Guys,
Please help!
JW0 - Millennium Jade is the paint code for the R34 GTR Nur / cam cover.
I thought Millennium jade has more a greenish shade to it (pic)
i'm after more a goldish colour as above.. or is that just camera angle? :wave:
Edited by Tommmo
Its alittle hard sometimes for Millennium Jade as the camera angle / lighting can effect the look.
Also ppl try to replicate the colour and sometimes don't get it spot on. Millennium Jade has a Light Gold Pearl effect in the sun and in the dark its pretty much green
Whats closest to a goldish colour is, EY0 - Silica Breath (Champagne Gold) Some of the R34 GTR M-Spec Nur's came in this colour... Very rare!
Thanks heaps for that.. just to make sure, EY0 is the same as the pic below?
Edited by Tommmo
Yes, its similar or very close I say.
Here is the list of Paint Codes.
BNR34
TV2 - Bayside Blue
QM1 - White
KR4 - Sonic Silver
KV2 - Athlete Silver
GV1 - Black Pearl
AR2 - Active Red
EV1 - Lightning Yellow
LV4 - Midnight Purple II
LX0 - Midnight Purple III
WV2 - Sparkling Silver
QX1 - White Pearl
EY0 - Silica Breath
KYO - R34 Z-Tune Special Silver
JW0 - Millennium Jade as you know is a Greenish colour, EY0 - Silica Breath (Champagne Gold) is the only other colour which I believe is the one you like.
That should narrow it down, so I would say so.
Cool!
BNR34
TV2 - Bayside Blue
QM1 - White
KR4 - Sonic Silver
GV1 - Black Pearl
AR2 - Active Red
QX1 - White Pearl
EY0 - Silica Breath
Cool!
Awsome, thanks heaps for your help
sh!t that looks alot like... my engine bay!
lol
That looks greener than it is, here's another one
JW0 is the right code.
:down: No worries!
lol
Hey buddy!
If that is your engine bay, you got the right paint code yeah...? If so,
Just goes to show in the dark it looks alot greener then in the light... Yeah...
  • 3 years later...
He Dudes!!! I search the Original Clour Code for the RB26DETT Valve Covers like this! http://i291.photobucket.com/albums/ll301/Ryu77_photo/RB26CandyRed03.jpg
My R34 GT-R RB26Dett was painted in Japan from my previous owner in a other color.....i will made it Original! but Nobody in Germany have this one -.- It is AP0 Red or Cinnabar Red CNR? I Don´t know!! Please help me!!! thanks from Germany!!!!
AP0 is not Cinnabar Red.....Cinnabar Red is CNR...AP0 is "Red"
  • Hersteller: NISSAN
  • Code: AP0
  • Farbtonname: RED (1)
  • Vorlagennr.: 034719
  • Version:
  • Farbtonänderung:
  • Qualität: 285 - PERMAHYD PERLMUTT BASISLACK
  • Lackaufbau: ZWEISCHICHT
  • Lackoberfläche: GLÄNZEND
  • PB:
  • Standarddatum: 30/07/1998
  • Formeldatum: 14/03/2001
  • Revision:
  • Formelnr.: 1429459
  • Code: CNR
  • Farbtonname: CINNABAR RED
  • Vorlagennr.: 766566
  • Version:
  • Farbtonänderung:
  • Qualität: 293 - PERMACRON VORLACK
  • PB:
  • Standarddatum: 17/04/2005
  • Formeldatum: 13/06/2005
  • Revision:
  • Formelnr.: 3522580
What is real?^^ But Thanks for the fast answer
  • 3 weeks later...
does anyone know the code for flat black rb26 covers, mine are brand new but iv modified the timming cover and now needs painting to match , cheers
Like what Terry said!
Give Chris a call and he'd work it out for you.
+ he has helped me out a few time with painting tips :thumbsup:
I am also in the process of repainting my cam covers which are orig in that Goldie colour,just to check is it millennium jade or silica breath paint code that my painter needs, cheers Ewen
If you are after the 'Goldie' colour then, Silica Breath (Champagne Gold) is what you want.
Millennium Jade is more of a greenish colour.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
