yeh dude its the same old thing, kenmore nandos at 630, moggill rd baskins at 730
hows the head comming along smity?
errr? :)
..oh yeh his engine... :)
Drifts tonight? yay nay?
Haven't had any time to do anything yet.
Will probably do something tonight, I will at least do a compression test if I don't feel like actually pulling it apart yet
Kebabs is serious business Taz :) We got financial close today w00t. After 9 months of pissin around its finally all sealed and the job is ours. Now we get to start building this motherf**ker!
you guys seen the drive thru kabab joint out wynnum way?
drive thru kebabs. will have to check it out. hadn't heard of the place before
on a side note, i drive along milton and onto centenary every thurs night after basketball. will try to stop by baskins, depending on what time my game is
wtf... drive through?
faggots the bunch of you. kebabs are to be made by sweaty arab men in the back of a trailer that's parked next to a servo, not out of a drive through, not out of some shop with asian workers, not as part of a franchise and definitely not toasted.
you fags in QLD couldn't organise a root in a brothel when it comes to kebabs.
alrighty then, any kebab joints you recommend in melb? going there for state of origin, and staying a few extra days to soak in the great weather :whistling:
Haci's Bell St Preston
Mr Funny's on Spencer St Melbourne
Ali's Kebabs on Mitcham Rd/Doncaster Rd
Uncle Joe's on Sydney Rd
Fun City Kebabs on Ballarat Rd Sunshine
and if you're one of those prats that refuses to eat stuff made int he back of a van cos your princess stomach can't take it, then go to Lambs on Chapel in the city. Although, make sure you ask for the Pide bread, cos otherwise those greek fuckers will put it in a roll and make you a souvlaki.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
