Astro's mums gold.
She loves it.
she'd love it more if it lasted more than 10seconds - she keeps on complaining about it
ugh, poor lass
ugh, poor lass
anymore and she would be loose as my HKS super dragger cannon..
lol she needs a service! major one at that! stat!
Are the HKS super dragger's any good ? My r33 came with it already. I was curious if its good ?
Wooo wooo just ordered some Split fire's of eBay and gettin in contact with plazmaman about a new plenum and 72mm throttle body
Edited by Danski
yeah mate there good quality exhaust, mild steel tho, so she wont last as long as stainless. but by the time it craps out your car will be rooted.
sounds good, should hitup PCE for parts, rather then ebay. as for plenum, stock one is good for up to 400kw or something.
Sweet. Thanks.
Wats PCE?
And yeah i know i dont really need a plenum but it will be a bit of a power increase and it get rid of the horrible looking standard one.
What do you do atm?
I work in water. I'm a water treatment plant operator by trade and at the moment I work as a controller looking after all of brisbane's water (25 reservoirs) and sewerage pumping stations (314). As well as a few treatment plant's.
What do you do ?
What do you do ?
Wow that sounds cool.
Im a mine surveyor - Not qualified but just about to start study.
Work wants to pay for it so ide be stupid not to :)
Its not bad. Always wanted to get out into the mines. I've got my HR licence too. Is it hard to get into the mine work ?
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
