status on the SR boys?
had a good look under my car today,
Need new tie rod ends and pwr steer rack boots *guess i could add in spacers or rack spacers or somethng*, adj castors would be nice also need a hicas lock bar.
monday ill order a 3" high flow ceramic cat, finish off my exhaust system, tie rod ends, look at getting adj arms, suspension front and rear.. put in the new fmic...and take a look at my brakes. waiting on the sump goo i ordered before i put on my high volume sump lolz
oh yea i wirewheeled out the rust ontop of my strut tower thats right next to the quarter panel..
rofl now got a huge shiny whole :( ill weld it up and grind it back lol
sounds f**king awesome. hows status on the brake kits u were talking about?
very nice, make me proud. (fitment wise) !!!
f**k yeh man should fill out the gaurds nice, Old mate said they got an agressive offset (+22), might even need to get he front gaurds rolled :(
Edited by Danski
Wooooooooooo bought new wheels today - Rays CE28N 18x9.5
What yas think?
i <3 ce28s!
powder coat them flru orange or a dark green - will look sex on your white r34 :(:D
i <3 ce28s!
powder coat them flru orange or a dark green - will look sex on your white r34 :P:/
lol u <3 everything that moves :(
Woah! Nice. Someone's rich!
I was rich b4 I bought the wheels and fitted the rubber on em :P
I cant belive they impounded a little pewi 50 from a 5 y/o
We should go there in our cars and do circle work in the park.....well ill be there anyways :(
What yas think?
I hate you :( I want these on my car but couldn't afford em so got my XD9s instead :P
f**k yeh man should fill out the gaurds nice, Old mate said they got an agressive offset (+22), might even need to get he front gaurds rolled :/
Should look f**kin awesome :P Can't wait to see em
Should look f**kin awesome :/ Can't wait to see em
Yeah they a bit of a stretch as far as money goes but micko talked me into gettin em :P
Yeah they a bit of a stretch as far as money goes but micko talked me into gettin em :(
Cant expect less from a Rays. If you're thinking of those colours Tristan suggest you might be better of getting the Gramlight 57d. Very nice rims for drifters.
Nah man just keeping em the way they are, not a massive fan of the fluro colours.
And im def not a drifter :(
ive said it before and i'll say it again,
mick for prime minister
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
