Nah all good man I gotta trade the guy that i bought them from for some others that hes got.
Just gota find something that I like and that fits my car better :D
I think anything more than 9 on gtt/gtst will scrub unless you do mods to it. From memory, the offset you've got are for GTRs... who are you getting it from anyway? What sorta rims are you looking at?
Im getting them from J-Imports.
Yeah the ones that I got were for a GTR but I thought I could get away with em on mine.
I realy gota get something thats staggered, like a 9 on rear an 8 on front....
Yea you could to make them look good but how are you gonna rotate them when the time comes???
Not gonna bother with rotating
Im prob gona end up running 275 on the rear and 245 on the front, itl just fit better that way.
where are you slack pricks? there's a boat here without a pilot... DBR33
Tragic, John, just tragic...
But I do love your art work!!! Mine is all undercover...
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
