one of the mounts had to be modified - I don't have the tools or skillz to do it myself. I hate giving my car to a workshop...
You're not alone. A lot of the work requires proper tools which just cost too much. Unless you're doing it all the time, I couldnt justify buying them.
Go the front pipe and cat on today and only took 1hours to get the job done today but if I were to do it myself it would have cost 3x or 4x as much and probably a day's work. Shit thing is, the bloody Catco cat got the protection plate welded on the wrong side, so now the side thats facing the floor doesnt have anything.
Thanks Tas for fixing the front pipe and cat up for me today.
Nah mine's on top too but dont know if thats supposed to be the case. I thought thats for protection of the cat or something (which means it should be facing down)... -.-; Couldnt be bothered. The old cat has both side shielded.
Edited by Brandon
the heatshield? yours ended up at the bottom?
Mine is correct (heatshield at the top)... also a catco
from a total n00bs view i would say the heatshield should be facing the top (the car)
but i brandon i'd go see someone in the know who has experience, im sure someone here can recommend a joint, and get it checked out
If thats a heat shield and but for protection of the cat then yes I think it should be up. But the funny thing is the old 1 has it on both side. In any case, doesnt really matter. I'm happy to have everything up without any big dramas.
^^ and ask questions
you guys are wankers :cool:
catco are preweilded cats so when we alligned it for brandon the cat senor was on the opposite side.
so in order to get everything working had to flip the cat so it all neatly bolts up
thats why brandon i told you from the very beginning to let me get you a magna flow hi flow cat as the flanges can be weilded to suit
so thristian before u start to slander me think carefully :D
Top.
If its serving as a heat shield then yes its better to be on top (if there's only 1 side) but it'll be better to have them on both wouldnt it? But when I look at other stainless steel ones doesnt seem like they've got any (on the photos).
Edited by Brandon
well in that case it is right. So Tas, the only reason you had to:
was because it was upside down in the first place :cool:. The only thing you would have acheived by buying a not pre-welded cat would be having to do more work welding the flanges on.
There is no need to have a shield on the bottom, there is no sheild protecting the rest of the exhaust underneath so why would the cat need one?
There IS (on my car anyway) a heatshield ABOVE the entire exhuast protecting the floorpan from heating up. The cat gets an extra one probably because it is a bigger source of heat than the rest of the exhaust
to protect from speed bumps and what not from scratching and rupturing the actual ceramic insides?
or to protect anyone who works on the car when the cat is hot so it has a heat/bash plate on it
and simply no..
the cat senor wielded hole was on the different side matey..
ive got a better and cheaper idea. get a straight thru pipe !! no one will ever know, cats suck !!
how many times must i say it?:)
are you boys coming up this thursday?
so I was helping a mate drop a gearbox yesterday so he can put his new lightweight flywheel on. Got the gearbox off OK, but got to the flywheel bolts and his snap-on battery rattle gun wouldnt even budge them. After ruining one socket and then trying another one, we drove all the way back to my place (he lives miles fking northside) to pick up the ute and my compressor. It also couldn't undo the bolts! Eventually we got 5 of them off, but 1 was still stuck. So now he has no car to get to work today, lol.
I have pulled many a flywheel off before, none have been as much of a c*nt as this one.
On the bright side it meant I didn't have to help him get the gearbox back on :)
did ya try heating the bolts and just using a normal breaker bar?
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
