hate you guys...seriously. On a happy note. I didn't realise AUD has been getting stronger against the yen again. Bring on 110yen to the dollar! Hopefully by the time I can afford to start buying some gear for the gtr it will have recovered fully ;)
some people are predicting we could hit over 100us before Christmas as we are one of the better placed ecconomies in the world so surely we would be over 100yen at that stage too, they are probably pretty hopeful but still our dollar is going to get really strong soon by all accounts
its strong agains the US dollar atm, mainly because the US dollar is so sh*t
currently .92 US or something and about 84 yen. So when (if) it hits 1US, It'll still be under 100 yen.
They predicted around it would reach parity with the US dollar around this time last year... then look what happened ;)
Edited by Smity42
omg servo food is making my guts so saw ;)
yes i have all ranges of sparco shiet in stock..
after a fancy pair of gloves to be like tsuchiiya?
lol no... more like a shift knob and shift boot.
why do you always get poisoned by servos?
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
