Wooo... sounds like I'm gonna be getting some muthaf**ken ERD coffee tomorrow morning!
Hey Adam! I see you lurking. Coming for the dyno day tomorrow?
Just got back from the shops and some c_nt has put a lovely big ding in my door.
God I hate 4wd owner's I really do. I think they all should be shot then stabbed then stabbed again before being shot.
:mad:
Serenity now, serenity now.
Ah,
don't like them either :mad:
Take milk. I used the last of it today. :)
Long or short black will do.
I wonder what time Yatala Pie's open.
hahah remember you me and megan at yatala pies - good times
Oh Martin, one other thing. Do you have car ramps/stands so that we can bleed my AWD system so it's working again?
huh? its not working now?
= win = no need for drift switch? :)
no.
= fail. because I want both.
not working = fail
I know how :)
Just need someone to help me with it, two man job (that's what she said) ;)
know how to fix it = win
Ah yes. I remember Megan. Hahahaha
John: Maybe the design of gts4 is similiar to gtr? If so, maybe its just a relay that'll do the trick for the 32s.
well it does work a bit (had car on the hoist and all four wheels spun) but it's not getting enough fluid through, so it's not working correctly, and the light is on. I think there's a big air pocket in the line because the car sat for so long. + old manky ass fluid.
If it still plays up after a bleed I'll get the relays checked, good suggestion :)
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
