Brand new dual compound tyres goign on the bike = col happy in the pants... :rofl:
i got rid of that rash too josh, little bit of metho and some jim beam...
rub jim beam on your balls and the metho is to drink to help as the bourbon burns your shaved pubes...
morning bishes
anybody want to bring me some breakfast?
fridge is empty and too hung over to drive at the moment
this
ouch
Oh stupid me . . . I was doing it the other way round !
:rofl:
Does anyone know where to buy 3m branded Di-Noc carbon fibre vinyl in our area? Dont really wanna buy it from 3m directly....
morning bishes
not bringing you breakfast... but... speaking of driving. Did you fix your intercooler* bracket yet?
*Brandon: IN TA COOLAH. NOT Oil cooler. It does the green stuff, not the brown stuff.
Shotty not
fucking...
STOP RAPING ENGLISH!
The term SHOTGUN means that you wish to accompany the person doing said acticity. Saying "shotty not" means you're going to stand next to the person who's not doing it... it doesn't mean you're actually out of doing it yourself. The term SHOTTY NOT makes no sense at all, and it should be illegal to ever utter it (except for purposes of my explanation).
If you don't want to do something you simply say "Not me" OR "Dibs on not".
"Shotty Not" is just another prime example of Australia bending the english language over the counter and aiming for penentration.
now... don't make me slap you like a bitch ;)
P.S I think that dude in the photo is now one of my heros :rofl:
Edited by Isola
not yet. debating braving the sun and going outside, but still a bit seedy and dehydrated, so thinking of putting it off until tomorrow.
going to the coast shortly for a few more drinks, so not even sure if it will get done tomorrow.
FOUND SOME MOTHERFARKEN PRINGLES IN THE BACK OF THE CUPBOARD!!!!!!!!!
WEEE HAAAAA
i was starting to contemplate eating the cat (no eating pussy jokes please)
f**king...
Shotty not reading any more of your posts :cool:
    • Sorry I didn’t explain myself properly, by free revving I meant if I just floor it, it gets to 7kish and will start to break up/not hit limiter properly, off boost I’ve driven the car until near on empty. I have a fuel pressure gauge mounted in the engine bay, holds fuel pressure consistently full tank or half tank even when revving, and no the pump sound doesn't change. all the fuel lines inside the tank are fairly new but will look into it, could that also be an issue with the lines outside the tank ?
    • Yeah maybe I got a bad batch that only lasted 6 years. Or conversely maybe I got a good batch that managed to last 6 years.    Either way I have sourced a set of OEM hub/bearing assemblies  so I keep hearing! Even from life long mechanics. Apparently this failure is unheard of…
    • I am trying to understand how that even happened to the hub... wtf
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
