thanks for the reply.
big bottom end would be an understatement :D
Cheers Josh - I forgot about Eug.
I'm looking at Bride Euro II, I think they are 99% same as 33 or 34 GTR seats??
man up and go fixed back :(
yea it sucks being sun burnt on ur back
but its ok.. reeling in 60+ cm mackerel is quite fun
if we used a better boat we could go on the otherside of morteon island and troll for huge ones
i might be going tonight.. doing a 3am launch mauhaha
Hai five!
Think I shall detail the car today.
Hai five!
I spent the day installing Air con units :). One in here is now rocking good (although the mount and shit need paint, and it is currently sealed with duct tape :banana:), one in the bedroom I just need someone to help my lift it up and in.
Air con for the massive win, however it was farkin hot out woodworking all day. Worth it though :(
blah blah blah purge blah blah
skinny emo f*ckers...
sif you would want to be a 45kg girly man, my knob weighs more than that...true story
LOL
g'day :D
I'm "working from home" today :D
and SAU isn't blocked here!
Nice One!
no one else seems keen on our epic scheme
No one else is a stoopid emo
I dislike swear filters
+1
I want to see if i can ebully him into weighing less than an average human skeleton
He'd have to put on 5kg...
So f**king hot outside, I was going to clay, polish n wax the car but it is just too f**king hot. I'll just watch some poker videos instead lol.
+1. See above :banana:
Edited by Smity42
pics of your sister or ban.
+1
I've seen her
Win :D
+1
agreed
+1
I'm the biggest e-bully/troll out there.
Tis true
nismoh im sorry i just ate kfc :)
and it was too delicious to purge
LOL. I just ate kfc too :D
my engine is coming out tomorrow....excite! :banana::banana:
Putting a dirty ESSSS ARRRRRRRRR in?
Reporting in
Reading you five-by
man up and go fixed back :)
+1
Sunburnt ftl.
At least when u burn, your skin matches your hair :(
Edited by Smity42
LLOL HAHAHAH i never thought about that one..
good one smity
lol
Which part are you talking about? He made like 17 zings at once in rapid-fire...... my head's still spinning
i have heard him mocking us
saying such things like "hahahaha i have the lightweight and the rb25 mwahahaha"
such a dog
and the highflow vl turb with t3 or t4 cartridge. :D
and im 41kg f**k get it right.
edit: josh msn more often
Edited by 32_Dave
Hahahahaha Dave the difference is our car's are driveable :(:banana:
miss understood previous post i see. (yoda voice)
you dont think i know already :banana: motor in next week after the brake lines are sorted :D
Fuuuuuuuuck yeah..... how much to go after that?
get motor running. bold up diff / drive shaft. bolt in seat take for test drive down street.
lol
but seriously.
- get brake lines (front solids and hydro handbrake)
- get motor in
- finish running gear
- finish wiring
- install all interior back
- paint 2 doors, bonnet, front guards, rear bar, reo's & bootlid (whenever the f**ker arrives, custom FRP bootlid)
- re-glaze entire car
- engineering, wheel alignment, rwc
- rego
- drive for 1000km let it all settle
- iron out problems
- TRACK !!! and beat it :D
the painting is the time consuming shit.
Edited by 32_Dave
painting is over rated
i was thinking tow it to track before its all done and hack it but everything wont be run in / bedded in etc... and ill have small problems that'll ruin a good night. :D
I thought cupping was more in your line. :)
He is good at it :)
Ill fix your back :(
The only thing I cup is a perfect short black in the mornings.
Coffee coffee coffee, oi oi oi, coffee, oi
Liar :)
lol
but seriously.
- get motor in
- finish wiring
- rego
- iron out problems
Lets fast forward to the :) ?
Yes . . Yes it is
P.S. Morning all :)
Thank you for everyone !! I have send the ticket to the transport and wait for them to put into the court!! I don't expect they will let me go easy but at least try my luck see the judge will believe the true or not!! Thank you again for everyone effort!!
ENGLISH FAIL
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
