tell him you know Ravi AKA Dirty Curry with the Maroon 33... he should be able to do better for you.
I regret selling my SSQ now.
SSQ are for wanksters
Tial Alpha-Q bov is teh bomb
Yes my indicators aren't the common type. I was expecting around $150 so I wasn't going to be a rude prick and haggle over it.
Thanks for the lead Ravi but with the net not working I didn't see it till after I bought it.
You forgot to add to that equation that:
Ravi = wankster... therefore....
lol
Ooooooooh check out the awesome new mods Tas did to my 33 last night, gotta be pushing roughly 15kw extra!
Hi,
What size hole do these filters fit in?
Cheers,
Martin
Hello, thank you for your email. please see your product manual for fitment. these are to suit the kambrook machines and jugs., Thank You - Regards *********
Thank You for your Highly Unhelpful answer. I am trying to find new filters for my water cooler, it is not a kambrook, but those filters look more or less right. A simple measurement would confirm it, but since you obviously can't be bothered, I will take my money elsewhere.
Cheers,
Martin
Interesting
I know right..... I was skeptical at first, but it definately has a lot more response in the low rev range, which is great for me as a streeter.
Hahahahahaha!! I thought something seemed weird going by your reactions..... to the same picture
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
