ppg = gearbox
ppi = plastic piping industries
RSL= return services league
YMHBJAIBHLN = your mum has big juggs and i banged her last night
oh getting off track here... soz
ppg = gearbox
How is ppg = gearbox ? I can understand the jugg reference however.
So in answer to your question
No. My mum doesn't have big juggs.
you are making me think of jake from two and a half men... really slow to uptake...
ppg make gearbox's and are commonly used in skylines for a drag racing application...
as this is a whoretown, nothing needs to make sence...
so if i say your mum has big juggs then thats what shes got...
My reputation proceeds me.
And no ppg isn't like juggs nor tpg. Tpg is a company selling intertrons. I bought three of them.
1. sence
1. This is how idiots spell sense, since they have no sense, they can't f**king spell it.
2. This misspelled word is also a form of since according to some idiot - English translations.
<insert any MMORPG here> chat:
Idiot: That doesn't make sence!
Me: YOU don't make sense! "SENCE" IS NOT A f**kING WORD, MORON! Sorry... IDIOT! Wait, no... too subtle... how 'bout, nub to life!?
Edited by Isola
yeh, had the same crap happen with tpg
usually they aren't too bad.
meh
we had a tpg fail this evening too, glad we were not the only ones!
Seemed to be pretty much australia wide. I was hoping for the zombie apocalypse
Truth.
THREE! I think that must have been their entire supply for a year
*Insert spelling Nazi shiz here*
I'm dissapointed in you John, you're slipping:
i am bender please insert gurder
*girder
P.S. Morning Mangs. Anyone got any steering column unis lying around?
Edited by Smity42
Sup mangs. Accidentally printed a defect report 65k pages long. oops. Cancelled it by the time it printed about 300 pages though. Small win?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
