Pretty much. But we have a housing shortage right? Not at all like the USA they overbuilt and...wait a minute....
As much as I would love to see house prices have a 40% correction overnight it would pretty much cripple the economy which I guess is a bad thing. It has to happen eventually though.
apparently i costs less to buy in New York than Brisbane now...wonder how true that is? I bet its not the case.
Check on ze internets?
You'd need to know what parts of the state compare to what parts of Brisbane though. I imagine some of the stuff up north would still be pretty exy, even if the city has dropped a bit.
FYI:
L1/SP126944 26/11/07 460,000
L2/SP126944 09/01/09 450,500
L3/SP126944 02/11/08 420,000
L4/SP126944 15/08/06 370,000
L5/SP126944 26/09/06 398,000
L6/SP126944 27/07/03 311,000
L7/SP126944 17/05/07 425,000
L8/SP126944 02/05/06 365,000
Lot 2, will be your biggest problem. IMHO we're in the same markey as 07 and 08, thats where price's are back at. Go in hard with a clean contract would be my advice
Depends how you look at the stats, if they are based on average incomes then yes it is true, otherwise it’s total BS
FYI:
Cheers even 450 is ok, I will get my sister to come around and make the agent cry, that should lower the price a bit
oh yeah i forgot about the whole adjusting to salary thing
Couldn't be bothered reading the last two pages......... too much serious bizzznatch bout money and houses.
Sooooooooo I'll just leave my input as:
SOMEONE GIVE ME 11ntyHUNDREDDOLLARS SO I CAN GO TO DEFQON1 IN SYDNEY
baaaaaaaaaaaaaaaaaaaaaaaahhhhhhh
/rant
DAM BUSTER TOUR UPDATE!!
The tour will be on this weekend ( the 12th and 13th of June ). After some numbers who will attend. It will be on in the after noon after 3pm on the sunday. If no one can make it, I will wait to hear back from Graham regarding another date. Beers will need to be provided as payment, as well as to drink. If we all chip in we may even be able to have a BBQ at the dam afterward.
EDIT : Forgot to mention max numbers of eight. BUT if it is a popular day then we can organise another one
IN!
In. You fockers can pick me up on the way through?
I was saying :D this weekend ( the 12th and 13th ) I was specifying a date sheesh
You are a confusing mang.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
