I have white skinny jeans. I do not look like a fag in them, at all.
also spotted Dan in some homo as CRV near James St
Me? in james street?
only if CRV = Maserati Gran Turismo
edit: A page to me!
Edited by Dan_B
Bull shit, i saw something that looked like the XXXX man driving a CRV
Wasn't me. I was on a test drive in that area at 3:30 - 3:50 but i was in the maserati that i have been replacing interior trim on for the past 3 days
with a proper auto box in them they are an awesome car to drive, the F1 and Cambrio Corsa are just crap driving around town in stop start traffic, but for really getting up it i'd go a proper manual box. Cruising around new farm was good fun
auto FTL.
I don't care if it's a triple plate clutch and I stall it every 3 feet. I'll be too busy beating off in the driver's seat to care!
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
