mang I have no idea. I'm guessing I swap trains at beenleigh around 6pm but not sure what time the train gets in to kuraby. might be easier for me to just take a bus to southbank and bus it in
well sunnybank or kuraby trainstation. i can do. or logan, if there is one.
im from sydney so i wouldnt know about brisbane trains.
im pretty sure taht the train from the coast should stop at either kuraby or sunnybank.
call me and we can work something out.
if not, may be able to pick up martin and his mates.
Just found 2 x 2009 Bmw 750's (top of the line 7 series)
Pair $550 for 4 hours... Seems great value to me... Thoughts?
Anyone got any company suggestions?
Ok mangs. Im leaving now.
Colon and smity have my number via pm so just call and let me know if ya'll need a lift.
Discriminating comments taht make me die a little inside, here i come!
*like*
Edited by mosquitocoils
Found another alternative, but its bloody expensive...
Plus I would want to drive it not have it follow me...
I mean I dont even get to ride in the other cars... :D
For the money they charge I should at least get to do a skid in it...
Nah, the rolls would be like an r33...
wait for the tidal wave to catch up when you stop...
Like it wouldn't be worth the look on Geeves' face as you drift his Rolls through a roundabout though :)
Edited by Isola
Lol John you're a dick.
Knackwurst was delicious, missing the 9:30 train was not so deliscious although there was a decent view while waiting for the train :)
Good night out lads.
+1
except for people not knowing how to direct me!
Sif, you loved it. Awesome scenic route!
finally got petrol.
V-Powaaahhh ftw!
Did you drink it?
BAHAHAHA
What the hell did you need directions for? It's the German Club...
We were giving him bad directions to make sure colon missed his train :rolleyes:
Like it wouldn't be worth the look on Geeves' face as you drift his Rolls through a roundabout though :cool:
*likes*
drift a rolls....
you'd need some massive speed into the corners to get the arse out on that 4 tonne beast...
That almost sounds like "I don't think I can do it" :P
+1. Soft :down:
Slow to begin with, but provides the lols later in the piece
Better, the lols are provided earlier without the slow boring lead up
+1
wurst was delicious
+11ty billion
missing the 9:30 train was not so deliscious although there was a decent view while waiting for the train :cool:
That wait for the train just flew by :P. I bet the extra half hour you had to wait sucked though :rolleyes:
Shame those hotties didn't get on the caboolture train with us :down:
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
