12 hours of staring at a puta screen...
I finds lots of stuffs ;)
lol Yeah I've noticed. I watched the turtle thing the other day (or was that this morning :) ) and was like, what the? but then I watched this and it took it to a whole new level. ha ha
Wow, well an update;
That debriefing session was massive (4 hours)...
I thought I went alright based on how many cars I over took, however my time needs much improvement to get anywhere near the front...
I set the forth fastest lap of the day, but only did it once... I need to be more consistent to get up near the front...
Most of my laps were 3 or more seconds off the front runners, only pulled 2 laps close to the front runners consistent times...
I also torched the car pretty bad apparently, tires wreaked, steering arm bent, rev'ed the engine way too hard and was un-kind on the brakes...
Today shows me that racing is not all about smashing every bit of HP out but more about technique and driving lines...
As I said I have much to learn... Driving into those blind corners is scary, very scary actually...
All you see is a concrete wall and you know what the corn looks like on the other side but then there is 6 or 7 other cars around you...
Popping exhausts & skidding the wheels under brakes across the shiny surface...
Its hard work too, my arms, hips & neck are so sore... The experience is priceless and im loving it but its taken more than I expected...
Aussie race cars were described to me as a fast go-kart, im yet to put words together that describes it accurately...
PS> Having a ball tho :wub:
So how does a general smo ( i.e me ) get to have a crack at what your doing ?
With about 70k for a season...
Or get sponsorship and make someone else pay the 70k per season...
I got a ride at QR through a mate, they liked my lap times and were desperate for a driver for two rounds this season... My story i a bit different...
I will most likely never drive again after this weekend, it was more about right place right time for me...
The regular driver will be back next round to take his spot back... :wub:
PS> Having a ball tho :laugh:
The regular driver will be back next round to take his spot back... :laugh:
That sounds so awesome. Any video footage? So this is proper door to door stuff right? Are the cars a step below V8 supercars or same regs n specs?
Scarnon mangs?
Windscreen chips getting fixed today. Indicator canceller is fixed and the rest of the S13 stuff might be in by this arvo :laugh:
They are a half scale car powered by a motorcycle engine and transmission (geared to the changes)...
Yes its door to door racing, more touch's than the utes most sessions...
Its tight and particularly scary in a concrete jungle...
It has become very popular with up to 40 cars on track at once, it costs a 1/10 what a supercar costs to own and run...
Here is video from clipsal 500 eariler in the year...
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
