yeah, i've officially re-assesed them, since they are metal and that knob is functional, I like them :P
a little on the pricey side though :) EDIT: And none with black lenses without going "custom" (uleh)
looking on ebay now...
Got mine for $250 on fleabay. Cost me another $250 for my prescription lenses.
You COULD get them in black iridium back in the day when you could still get ruby... dunno what their lens situation is now though...
i have the titanium juliets with gold fire lenses, best investment i ever made. i always used to snap the arms on my plastic oakleys. mine have been around the world, smashed, droped and squashed daily as i get out of the skyline!
do it!
oh, and you'd catch me in those orange ones! i like em!
My plastic ones (old model straight jacket) that I broke on friday, I have had for well over 5 years
You don't count; you're a ranga.
Mine are Hugo Boss aviators, titanium frames, pretty strong lenses. Cost like $300. Better than white boy Oakleys! :D
quiet, darkness
I has Ray Ban's.....
If I was going to have something other than oakleys, it would be ray bans. However:
I only rock oakleys :D
fark me, this whole page is all about freaking sunnies
In Soviet Serbia, Sunglasses wear you
That statement is blatantly untrue, Dan said something about a windscreen.
P.S. Morning mangs
Jordan Sparks raises a valid point
"Tell me how i'm surpost to breath with no air"
Stupid women, the idea is you don't breath (aka die)...
pffftttt dumbass
my main ones at the moment are my arnette rage's
i want these just for the name
pffftttt dumbass
^^^ wooow...
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
