Morning mangs.
Slept in today :banana: , So now I'm stuck at work till almost 4pm :banana::D:(
Hows the p1g going colon? Rip a good skid yet?
Webber for WDC 2010!!!!!
Almost 4pm oh noes :)
No skids yet.
Hahaha Vettel was pissed
What happened?
Guy didn't send them.
What happened?
They never turned up, seller vanished off the face of the earth internets
Paypal ripped $530 off his credit card and gave it back to me though :)
Edited by Smity42
Dodgy seller fails at being dodgy
'allo guv'ner!
Yeah, but it means I now still need to find front brakes :)
Yeah that bites....
Onto other news, watch this vid. Look at 5:16. You get to see Tristan drifting...... I mean doing it wrong
damn, will have to wait till I get home
By 'doing it wrong' are you saying he's doing drifting wrong, or are you correctly pointing out that drifting itself is 'doing it wrong' as the fastest way round a racetrack is with grip? :)
ahaha, just hanging out on the side of the track.
I've been looking at alot of the import lots to get an idea of the prices of some of them. They really have come down in price but I'll still be prepared to pay 50 for a 34gtr, unless someone really wants rid of it and it's in good condition.
Job interview today!
45k will get you a decent 1999 GTR. DO ET!
Just had a quick look and 45k will get you a new SS Commodore, Ford 6 turbo or an XR5 Mondeo...
The 34 won't depreciate nearly as badly as a new car. May aswell by an 08/09 Commodore/Ford and save yourself 15k.
By 'doing it wrong' are you saying he's doing drifting wrong, or are you correctly pointing out that drifting itself is 'doing it wrong' as the fastest way round a racetrack is with grip? :domokun:
Yes
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
