26 days without any liquor
reckon i broken any records yet?
its my pre-bucks detox...
so when i drink saturday night ill get plastered...
I reckon two pots and you'll be blind.
I'm over this skyline.
When giving it a bit, it spits (has always done this) feels like its about to stall then it keeps going, eventually will stall though.
Coilpacks or plugs again?
Another guy reckons upgrade the afm or buy a new one. It's got the pink sticker rb25 one on it atm.
Well have a nap, Then fire ze missiles!
Re Stupid 25. Try cleaning the afm. Coilpacks already been replaced? If not maybe give that a go. If the coils are going I would try to find out which one it is then swap it to one that is working to check that it is the coil packs or the spark plug.
Martin/John,
I'm wanting a new computer come Xmas time. Requirements. 2 monitors minimum. Will be used for internets, poker, and uni stuff. Cad/Suretrak/CostX etc. Want decent hard drive space 1tb should be fine I like to keep everything on external drives mostly. DVD burner etc. Semi decent sound for tunes while working. Budget $1500ish? incl Screens?
Martin/John,
Is 1500 your max price?
I'll have a look at suppliers and see what they can work out but xmas time is a long way away in the land of technology. What you buy now for 1500 will be worth 900 come xmas time.
EDIT: Tell me what you think of these, keep in mind these come with a 1 year warranty, I can do a deal on the screens for you. Otherwise, I can do up a custom one for you from myself personally however it won't come with the one year warranty.
Edited by hylian
Yeah, as the guys have said, no point planning now for a purchase at xmas
HOWEVER
I don't see a problem with your budget for what you want. You won't get a powerhouse for that price, but you will get a decent midrange system. I don't know the requirements for Suretrak/CostX but I see cad as being the most hungry. A few years ago you needed a powerhouse for decent cad performance, but these days any midrange desktop with a big chunk of ram will do nicely.
So yeah, hit us up again when you are ready to buy. Between all of us you'll probably get a few options to pick from :worship:
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
