That guy in the purple/black whatever it was nx coupe gave me the thumbs up as i left last night.... guessing he was eagerly waiting for the moment as he drove passed about 20 times :)
That guy in the purple/black whatever it was nx coupe gave me the thumbs up as i left last night.... guessing he was eagerly waiting for the moment as he drove passed about 20 times :D
That guy was a tool.
bucks;
so we got just under a pallet of booze
* 96 cans of jim beam
* 48 cans of jonnie
* 96 can of bundy
* 96 coronas
* 48 super drys
* 48 asahi
* 48 harn premium
* 48 new
* 24 cans of stout
* 48 pils
* 48 bees neez
* then a 700ml bottle of jim, jack, jager, bundy red, glen fed & tequila
* 48 cans of red bull
28 people coming
hired tent thing in the back yard at a mates place at everton park
we got steak, steak an some steak
4 girls to cook, serve, deal poker (sexy undies to begin with then topless then bottomless as the night goes on)
a sex act thing with a 5th chick (30 minutes)
loads of poker, booze, loud tunes and yeah then we might hit town... maybe
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
