How exactly is this supposed to work ?
It's a one handed keyboard. For people missing an arm, or with like... palsy and shit. Used to work with a bloke in Townsville that used one because he had a stroke or aids or something, that stopped his left arm working. Kept up with the slowest typists in the room (the 40wpp crowd)... so I guess it works ok.
The only problem was that every time he started a shift, a two hander would have to plug in his keyboard for him.
http://www.maltron.com/maltron-kbd-dual.html
Apparently you get away with using less downwards force to type, and the split design eliminates wrist twists.
I'm looking too much into this aren't I hahaa
Looks retarded :D
Allo ladies.
How's teh ike's Cream?
Allo lady
teh icecream was good, as was the entertainment
It's Scarlet... who the hell cares what's up with it?
QFT. The things I would do to that woman...
Nah, I don't care when it's someone I know can pull up in a hurry if I have to anchor it. It just pisses me off when the great unwashed do it.
That's what she said
This looks interesting.
I'm not sure but I must find out what that red button does
Morning mangs
I <3 RS-Rs
Special request, can we at least keep this thread half-arsed SFW when it comes to pictures? At least during the week?
Allo lady
Morning mangs
I <3 RS-Rs
define SFW :D
define SFW :D
Chicks with clothes on are generally OK, although massive pictures that fill my monitor with tits/arse are not great. Ditto for massive pictures where the chick is wearing bikini/lingerie/nothing.
Don't get me wrong I'm all for it, but I like having a job, and I also like using this thread at work... so hotlink or thumbnails for those types of pictures would be grand
Its on like donkey kong for alfa engine removal tomorrow morning, please come and help if you can (It shouldn't take long). I mainly need a hand to push the car around, as it has no brakes :D
Lets say around 9am?
Also colin, do you still have my gay chromies and merc wheels? how many tyres in total?
Its on like donkey kong for alfa engine removal tomorrow morning, please come and help if you can (It shouldn't take long). I mainly need a hand to push the car around, as it has no brakes :P
Merc wheels and tyres is like 6 wheels and 2 or 4 tyres i think. I would come and help mang but this assignment is going to f**k my weekend. Sorry mang.
Its on like donkey kong for alfa engine removal tomorrow morning, please come and help if you can (It shouldn't take long). I mainly need a hand to push the car around, as it has no brakes :(
Will be there at 9. Can only stay till about 11 though.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
