Personally i would prefer good wet weather braking over good traction in the wet.
Why not have both! Braking in the wet at traffic speeds is only gonna be as good as your front tyres!
I hearya dude. both is great but i become miss daisy when it rains. Traction even in the worst conditions will not be an issue to me.
Lol,
Seems to be a right royal clusterf*ck at work today. Email Down, Internet Down, Document Management system down, 90% of all other systems down.
Glad I didn't make it in, somebody else's problem :thumbsup:
Edited by Smity42
Too much wet this weekend. Garage got 2" covering and it almost came inside the house :thumbsup:
I put some oober drainage out the front too..... stupid thing got blocked between the street run off and the drains I put in... grrr.
Yeah, Rain is good, the grass seed we threw out last week is about two inches long, but at the moment 70% of it is under water. I think it's drain digging time, when it finally stops raining on the bloody weekends.
I just have more weeds growing :thumbsup:
And haven't been able to mow for weeks
havent had to mow a lawn in like 18 months because of the horses lol. That's the only thing they're good for.
Apparently they taste good too.
Lol,
Well, we just had people bring in old crt monitors asking why they werent working. The things were filled with water because they left the window open :\
My coon's brakes arent too fantastic, they shudder in the dry (even with new rotors/pads) so it's a good thing I only had to drive to aspley and back this morning and then 5 minutes to work.
I was thinking about how awesome it would be to have awd today, getting up a hill with t/c on wasnt fun.
It's raining fuccking sideways!!!
Lol, I opened the garage door this morning, saw that, and instantly thought of Forest Gump giving a breakdown of the different types of rain.
sup mangs. Scored a full exhaust for the GTR. Front pipes, cat, and 3 inch catback with canon for $220. Bargain.
by scored, is another member going to start a thread in a few minutes saying "some cunt stole the exhaust off my r32 gtr."?
today's drive to work was great fun. No one on the road cause you couldn't see more then about 20 metres in front of you this morning
I had eleventy billion people in front of me today! How come you got so lucky?
for noel
The Exige Type 72
The Exige Scura
Which are all the same as these - Exige Cup 260
All 260Hp 2ZZ-FE toyota supercharged engines, the only real difference is the Type 72 runs Bilstein/Eibach suspension and the Scura and Cup 260 run full Ohlins external cannister race suspension. All of them are around 900Kg on the road.
Edited by Dan_B
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
