had to be up at 6:30 for the tradies to begin work at he house... :D
only got home at 11pm from cooking school so now im wasted for todays day at work...
i got a pc (obviously), xbox 360, ps3, wii, ps2, ps, xbox, meda drive, nintendo 64, snes, nes, atari 2600, sega master system & a saturn system...
so when it comes to gaming platforms, i could not give a shit... as long as i got's me games... :P
I might or might not be there this evening.
Have a work meeting at 4:30pm, that will probably go till 6:30pm, so not sure if I can be fucked doing anything after that.
Oh yeah? Well I have a chess set, connect 4, battleship, star wars monopoly, and a pack of UNO cards. So there :)
Don't be soft :P
now you guys got me on ebay looking for old snes and nes games... damn u
I won't be there surprise surprise.
Next week I shall
Your lies are tearing this relationship apart ;)
I had Wahoos for lunch. It was awesome. Korean tilers suck donkey balls. End.
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
