How good is this, the ladies in the office have cranked up the AM broadcast for the cricket.
Dang, I'm stuck with interwebs live commentary :D
Could put cricketTV on the phone but the boss might not like that :bunny:
Lucky!
FFFFFFFFUUUUUUU, what drop kick picked siddle over dougie for the test side? :bunny:
And here you were doubting siddle
2 wickets already
his brother is a member and has a decent s14 on ns.com
2 wickets already
sh*t, when did that happen? Guess I'll have to eat my words :D
I don't mind siddle, but dougie is a legend.
Dougie would have 5-for by now :bunny:
Morning
Have to take the cat to the vet this morning.
Don't think she will enjoy the drive in the skyline, especially as i don't have a cage, and she'll probably be going mental in the back.
Not willing to take her in the golf, as I don't want her claws anywhere near the leather seats
we could have lent you a carrier, next time you need one hit us up!
Shall do. Was a last minute thing. Damn cat spent all of last night vomiting, so took her in for an examination.
Hopefully the antibiotics work, otherwise $800 worth of xrays, sedation and blood tests is coming up.
yeah we had that when we first got our cat, lucky we had insurence. The cat learned not to eat rotten stuff from the bin though! lol
notice to all:
the gabba has banned back packs with more than one opening...
WTF.... how can i smuggle shit out of the corp box now... :(
tell them their mum has more than one opening
Looks like siddle got 3 wickets while I was driving home... officially eating my words now.
Was it a hat trick? I should have come home earlier :(
They were consecutive balls.
how the frick was that a wide??????
the douche clearly forgot it is a test match. Siddle was the perfect selection for this pitch.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
