F*cking drop kicks we were playing in indoor tonight decided to get in a fight with the umpire. Then one got sent off, so they walked off. We didn't get to finish the game, and I didn't get to have a bat :(. Shit Blokes, all of them.
/rant
had that happen every now and again in basketball. my other pet favourite is when the other team forefeits, but neglects to call the centre beforehand,so you drive out for nothing...
i thought the 2 teams playing the game before us were goin to start a punch on with each other, well, the yellow team wanting to fight the white team, funny thing about the yellow team is its kinda racial.....
I've had arguements with sparkys before, they get paid far too much for something a monkey could be trained to do.
shit day was shit, really need to get some sleep tonight, no gt5
The guys who do all the substations and stuff like that are pretty handy. I wouldn't want anyone unqualified doing that shit but all the house stuff n low voltage shit is meh.
/rant
I hate it when I don't get to bat.
Yeah that was pretty intense. Was like Japan had turned on Germany.
"do you expect me to talk... no mr bond, i expect you to die..."
best line ever....
Agree.
Sarp Mangs what's crack-a-lackin?
Morning Mangs,
Yeah agreed.
I went home and had a solid minute and a half batting session thinking about your sister.
HAIL!
Test match starts tomorrow :) We will probably lose :(
No footsal till feb I hear? Who's up for some indoor cricket?
Morning Mangs,
Yeah agreed.
HAIL!
Looks like you got some efflorescence problems :ph34r:
Who's wall is it then?
Ya mum's wall.
Naah its the car park @ woolies Petrie. I just approved of the sign.
Sparkys have isolated the power board which our A/C runs off = no A/C in office = Gay.
Go home?
What do you do for a living Col? State office sounds ominous. I had to go into head office in Brisbane last week for a design meeting. Very nice place but I'd hate to work there it was so quiet in the office.:closedeyes:
Ya mum's wall.
Go home?
Yeah I could but I don't think they'd be impressed. I've been ridiculously lucky the passed 2 weeks. Few days I've been getting in late like 7ish, everytime I've been running late so has the Site Manager and I've managed to get in before him. Winrar.
Martin, I would suggest finding a girl that would let you touch them, its much more fun than touching yourself thinking about the ones that wont let you touch them. Just sharing some wisdom I have accumulated over the years.
You used to be fun...
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
