thanks guys, i just hate funerals... and the wife is ok, it was their time...
wish i didnt have to go to the funeral, would rather be working on a hot engine in a tin shed in the middle of summer...
this
What are you using at the moment Jeremy?
You just had a highflow installed, didn't you?
Still stock everything ATM, but I have plans for hi-flow R34 turbo and nistune...... plus this, plus that, then that and then another that.
Keen. Got harness and everything needed for it? How much you want for it?
EMU.
http://i21.photobuck...ur/IMAG0038.jpg
Universal Harness.
http://i21.photobuck...ur/IMAG0039.jpg
Comes with CD and Shizzle.
http://i21.photobuck...ur/IMAG0040.jpg
$500.00
commiserations Col ad Missus Col
EMU.
Universal Harness.
$500.00
You can keep your spark plugs :P
So you just wire that harness into the car's loom then off to the tuner? Is there wiring info on the cd?
I shall consult with my official mechanic when he gets back from the sticks and let you know.
Col, not good mate. Just make sure you look after yourself and your wife.
McFly, what ECU are you running? A Chipped 33 unit? The SAFC might not allow you to do much besides trimming some of the fueling points. They work great on stock management if you want to up the boost a little on a 'stock' setup.
McFly and Jez, Nistune is the best option in my opinion as it keeps things looking stock and gives you the same *or similar* level of tunability to that of a PFC. Being that you both have 33 setups (McFly I'm assuming you're running S1 33 ECU and loom - or is it a fiddles 31 setup?), The Nistune requires a little jiggery-pokery to work. You will need a Type 2 Nistune Board and a 32DET Ecu or a Z32 DET/DETT board that requires some internal modifications. The mods alter the firing order of the injectors and trigger for the coilpacks.
Type 2 boards with Nistune software go for $420 + GST, then you'll need to find yourself a 32 ECU which I'd allow for $100. Misso might have his laying around somewhere, so bug him. I can solder the board into it for you no worries. The software is nice to use giving you easy options for upgrades. Select the type of airflow meter you have installed and what injector size and it will trim the maps to give you a good base to start from - in a tuning sense.
As for turbos, the more understated it is for a daily street car the better. That 3076R is a nice turbo. A mate of mine had it one with a machined out T28 .63 rear housing on his twin cam 2ltr MX6. The thing laid down 425hp atw. Problem with his was that it was internally gated. Boost control became an issue. That turbo requires it to be externally gated and I think with the housing size will be a let down if you want to keep the same sort of response you have currently.
A complete bolt on kit like a GT-RS or a high flow will be the better option IMO for a street car. I would lean towards the highflow as it can be passed off as`stock and means you don't need to fiddle pipework, etc to fit.
*end book*
Yeah chipped S1 33 ECU
Yeah mine is essentially a 33 S1 engine loom, just minor fiddling to get it to mate up to the 31 main loom. Nothing that would affect the ECU.
I could find an R32 ecu (looks at ute)... but doesn't that lose the VCT or something?
Hmmmm......
So in short what you are saying is: it will be a bit laggy?
I would rather have better response than a few moar killa wasps, so I might stick with the high flow option.
*end book*
A properly good tome, that was.
Edited by Smity42
If you want to keep the VCT you have to go with the z32 ecu.
Just called 'bribane turbo and tuning' or something like that, over at the gabba
To rebuild stock rb25 turbo, assuming parts are available, around $700
To steel-wheel: extra $350ish
To rebuild, high flow & steel wheel: around $2000
Poooooooop.
Poooooooop.
Dang....
Poooooooop.
I didn't think they rebuilt turbos themselves. Pretty sure they source it out. GCG has a great reputation and pretty sure they do their highflows for less.
Hypergear appear to be gaining popularity with their cheap highflows, but I am not sure what their reliability is like.
True... funnily enough I just came across your ad on boost from November, selling an Rb25 turbo. You still got it? I might be keen, to send off to hypergear/GCG to high flow it...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
