1st question - store open?
2nd question - Miso/ Scott where will I meet you guys at Forest lake?
what's going on at forest lake?
what did i miss?
Wooot picked up an R34 turbo in sweeeeeeeeet condition :D
Can I has it?
Just found out Hell's Pizza at stones corner has no power, so prob no icecream at baskins.
Meh, if not we'll drive around till we find somewhere that is open...
Late reply.
I am skyline less at the moment, so no stones corner for me.
Picking it up tomorrow from ERD. Turns out the boost controller was playing up causing it to ping
No worries getting there tonight, easy drive in from the northside.
Just throwing it out there, Clem7 entry to the tunnel was pretty interesting tonight, might not have been the most legal move
posted elsewhere but it cant get too much exposure imo.
Qld cops. Ipswich was about to be destroyed by floods. People all trying to get in or out depending on their situ, Bridge about to be closed and 400 metres up the road the pricks set up a speed camera.
Never have I hated anybody as much as that arsehole sitting in that van while all around him the world was in chaos.
c.u.n.t. is all i can say
Morning Mangs,
Petrie bridge is open again :D
Contra-flowed both directions on to the lower bridge though, that's going to be a real prick anyone trying to go north on it in the afternoon. It gets bad enough with two lanes open let alone just one.
Upper bridge must have some structural damage I reckon.
Yep
Not as illegal as the douche that nearly ran into us going the wrong way down the road...
Clem 7 open again now?
Did it ever shut? Yeah its open now and toll free. Im pretty sure all toll roads are toll free atm (if they are open).
You would think they would have better things to do hey? What pricks.
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
