I've run out of crayon's though.
Nikko pen will be acceptable
Jason you keen for German club?
Suspended in my work = sacked lol.
What time?
sacked,suspended, given the arse and getting a DCM all the same thing.
yer suspended at my work normally means escorted off the premises, they know we have sticky fingers and will take anything even if its bolted down
Although the word mistake at my work can range a fair bit, anywhere from a talk from the manager to a court case for manslaughter
I have a lot of colour pencils. The project manager saw me marking up scaffold drawings in coloured pencil and he was like
PM: Are you marking up drawings in coloured pencils?
Me: Hell yes
PM: You do your planning in coloured pencils?
Me: Hell yes
PM: f**k yeah I love coloured pencils.
Me: Hell yes
Me: Hell yes
Lol
and, anybody got an angle grinder I can use, or that can do a slight trim on couple of choice metal bits on my car.
cage is being a real pain in the ass to install
one long pain in the ass
jason i think what you are looking for is called "bailey channel" Im not 100% on this but pretty sure its near enough for someone to know what your talking about
I has angle grinders
you coming to german club tonight, and if so, are you going past your place first?
I just have one support bit where the sunroof used to sit fouling against the cage, so just need to trim it by about 5mm
Had a morning tea this morning to raise funds for the qld flood appeal. Everything that got donated Brookfield is going to match. So far from the head office sites in Brisbane we've raised nearly 13 grand. Solid effort by everyone :cheers:
Or, I can swing past your place at some point in the week and you can have a crack, as I haven't used an angle grinder before....
I am, and I am home now. Can bring it if you want. Angle grinder on the train will be baller. Just let me know coz I don't want to bring it if you don't want it.
If you like, although I can take no responsibility for unwanted metal damage...
Awesome stuff. Powerlink is also matching donations dollar for dollar. Was just over 20g this morning.
also keep genitals away from the spinning bit too
Since when are genitals not body parts?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
