Ok, old man has delivered, so will get my angle grinder on this afternoon.
should be interesting.... ahh well, what's the worst that can happen?
Blood, guts, genitals....
Or a bigger hole in the roof to patch up.
Morning Mangs,
Late notice german club was awesome. Pork Knuckle ftmfw.
Nervermind. At one point in time, I. will. attend. said. German. Club.
Pork Knuckle sounds dirty....tehehe
Which one??????
tehehehe
The first one was the best. Second one was alright I guess :whistling:
Sisters?
fark your mitsubishi i got a horse outside
Ride your valiant steed!
Morning Mangs!
F*cking bridge is closed at petrie again (indefinitely). And youngs crossing rd too. Took me 1hr 15m to get to work :(.
Might have to start catching the train untill they fix that f*cking bridge.
Yay... bridge
Hai Scott! :action-smiley-069:
ECUs are on teh way from J-Land :)
Hai McFly! :action-smiley-069:
Yay for ECU's
THIS! Top job orgasmising mang.
Fixed
JASON!
Said like Maaaatt Damooooooon *local tard voice*?
That's what she said.
Twice
This man is on a horse.
Not just any horse
Um.... Dad..... am I meant to be able to see the road when I drive???
And Jason, hurry up and reply to how the hell you got defected..
He dropped someone off and had stopped enxt to a cop on a bike. The rest is his story.... (See what I did there??)
Just be careful of the flying sparks. They will PWN any glass they touch, can potentially set fire to fabric/carpet etc (if you have any interior left) and can also damage paintwork if they hit it.
Also WEAR EYE PROTECTION.
+11ty.
Always keen for more Deutschern Tavernin.
Joshwua loves a good pork knuckling...
tehehehe
tehehehe
Sisters?
Colin's Sister?
Yay... bridge
No bridge :( Not yay :(
Yay for ECU's
Yer... f**k import monster though.
Twice
What is it with you and genitals??
Some kind of fetish there I think...
Wrong Jason
Correct.
I am anal about eye protection these days, but even for the not anal it's a must for grinding
do it
Shuddup, NA Fanboi :P
Better move fast if you want that one.
Yeah that one will probably vanish.
But in general, GT3076 or GT3071, how will they compare to a high flow as far as response/power goes?
My 3076 .84 made 310rwkw at 16psi. It was quite laggy and in hindsight compared to what i have now i wouldnt reccomend it.
Probably another 1000rpm laggier than a highflow but will make 300+kws instead of 240ish. Complete guess based on a quick scan through the turbo results thread in Forced Induction.
In another news. I've booked in my Q Ride for 29/1/2011 booyah
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
