This pleases me...... and it's ok, I don't even know what shifter you're talking about hahahaha
That's what she said.
Excellent...... congrats on the head lotus thing!
Mmmmmmmmmmmmmmmmmmmmmmmmmmmm head lotus
Hehehehehehe... you said 'thing'.
Jason you might wanna be careful posting stuff like that on a public forum
+1
What do they have you doing Bunta ?
In charge of the area that amends, renews, tranfers ect water licenses. Epic pay, but shite its boring, cant wait to go back to my old job and do somthing useful rather than just busy work.
Also in news, in less then 2 weeks time i am offically the main lotus technician in brisbane, i have training this year in sydney for the new models.
congrats dan
lotus song for you:
What size do you need? how high?
Changing the clutch in the 33 so it will need to go pretty high, something like 40cm minimum i guess. I live in Fig Tree Pocket, I can come pick it up from who ever lives closest.
Indeed.
<3
Buy a 31 coupe and I may just ask you to marry me.
You coming Thursday? I has ecu and nistune for you to butcherify.
Laser force this week? Or another week?
Are you flirting with me.... ?? Probably will be there Thurs night. CH?
congrats dan
lotus song for you:
Nice
Hoes have the worst crutches.
That is all.
Fixed it for ya.
I'm in Boronia Heights, so probably not the closest.
Can you see through time?
Now that would be cool.
Had a win this morning. Acquired the new Top Gear episodes at 1mb/s. Fastest I've seen it in a while.
Lucky guy. I never get anywhere near those speeds.
Have a go. If it don't work just use a bigger hammer :thumbsup:
Any suggestions on what panel filters are good / better / best ?
Get the Ls1 filter from a v8 holden. You can see through them but they still filter well.
Very unrestrictive.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
