This pleases me...... and it's ok, I don't even know what shifter you're talking about hahahaha
That's what she said.
Excellent...... congrats on the head lotus thing!
Mmmmmmmmmmmmmmmmmmmmmmmmmmmm head lotus
Hehehehehehe... you said 'thing'.
Jason you might wanna be careful posting stuff like that on a public forum
+1
What do they have you doing Bunta ?
In charge of the area that amends, renews, tranfers ect water licenses. Epic pay, but shite its boring, cant wait to go back to my old job and do somthing useful rather than just busy work.
Also in news, in less then 2 weeks time i am offically the main lotus technician in brisbane, i have training this year in sydney for the new models.
congrats dan
lotus song for you:
What size do you need? how high?
Changing the clutch in the 33 so it will need to go pretty high, something like 40cm minimum i guess. I live in Fig Tree Pocket, I can come pick it up from who ever lives closest.
Indeed.
<3
Buy a 31 coupe and I may just ask you to marry me.
You coming Thursday? I has ecu and nistune for you to butcherify.
Laser force this week? Or another week?
Are you flirting with me.... ?? Probably will be there Thurs night. CH?
congrats dan
lotus song for you:
Nice
Hoes have the worst crutches.
That is all.
Fixed it for ya.
I'm in Boronia Heights, so probably not the closest.
Can you see through time?
Now that would be cool.
Had a win this morning. Acquired the new Top Gear episodes at 1mb/s. Fastest I've seen it in a while.
Lucky guy. I never get anywhere near those speeds.
Have a go. If it don't work just use a bigger hammer :thumbsup:
Any suggestions on what panel filters are good / better / best ?
Get the Ls1 filter from a v8 holden. You can see through them but they still filter well.
Very unrestrictive.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
