Morning Mangs,
Another week...sigh. New HDD is f**ked on my computer. Won't come up in BIOS or anything. Tried all the different sata ports and power cables, tried every combo of settings in the BIOS and no dice. Finally tried it in my mates computer and it didn't so up in his either. So I've come to the conclusion that it's f**ked.
Did an oil change on the bike and got some new brake pads for the rear. Has a dead spot at around 6k and a slight miss around 10-12k. Think it needs new fuel filter, plugs and possibly the carbs cleaned.
Should have let an expert handle it ;)
Naah sounds like its borked. Take it back.
Morning Mangs,
Where did you buy it from? Places like umart and msy have horrible warranty services, best off buying a new one
It was all going so well. I was pretty happy with myself and then this shit stupid motherf**ked hard drive. Found out it needs a firmware update aswell something about write errors not being picked up or something or other. Think I'm going to change it for a Western Digital one.
Yeah people say that, but the one time I have had to return something to umart I had no issues.
You login to your account on umart online, find the order, then next to the product that is faulty there is a link to click to do an RA on it. Then you take it in to them, and they sort it out.
Downside is that sometimes you have to wait while they send it back to the manufacturer before you get a replacement, but hey, that's better than not getting a replacement at all, right? I would think that in this case being DOA they will just replace it though.
The one thing I had to take back was a video card (one half of an SLI setup). When it came time to give me a replacement, they could no longer get the same one, so they offered me a free upgrade to a newer and better one. This was no good to me though due to the SLI setup, so they were more than happy to offer me the value of the 'new' one they were going to give me to put towards a new badass video card, which I did. So basically yeah, pretty happy with their warranty service myself, although it isn't fast.
What brand did you get?
You used to be able to buy a set like this from samsung, for a couple of grand
i got a 3.5m screen now in my media room...
works better than that shit...
Everyone on my floor has disappeared. Sitting here in silence by myself. Have a feeling I'm missing out on free food.
Aw.
I had a mainboard die 2 weeks after I bought it through Umart, said it would take 4 weeks for it to come back so I just bought another. It would be better if they could just give you a replacement straight up.
Argh that sucks, I haven't had any issues with samsung drives up till now :(.
Are you sure you're not doing it wrong?
Seagate and WD is all I will touch, my boss bought 2 1tb samsung drives for a machine we were building that he needed same day, few weeks later we had to rebuild the raid as a drive had failed, a month or so later the other drive died and we just ended up putting seagates in.
I just prefer to spend the extra and get a more reliable drive, have seen DOA Seagates but the failure rate isn't as high as I have seen with Samsung. Then again, it could just be a bad batch of Samsungs we encountered.
Edited by hylian
Sup,
Back in Brisbane for a Job interview this afternoon, then back down the coast for the rest of the week. Had the HICAS light come on while on the highway. Pulled off to get some water, light off. Back on the highway and 20 minutes later light back on....grrr! Then, just to make an absolute ass of my self at the first red light I come to in Brisbane I turn the engine off to reset the HICAS light and the damn thing wouldn't start up right away! Bloody turbo timer and kill switch and alarm causing me havoc and backing up traffic on Coro Drive.
I vote me for dumb ass of the day!
I've got at least 8 samsungs spinning in my main PC, they are consumer drives (not server spec) but they run 24-7 and haven't had any issues. Also got them in my media PC, all my external drives, etc. I've been through probably at least a dozen before these ones too with no issues, and all have suffered the same abuse.
I won't touch seagate with a 20ft pole, had too many of them die on me prematurely. Maxtor were also godawful before seagate aquired them, and I do wonder if it is just the seagate drives coming out of the old maxtor factory that are bad. But there's no way to tell.
WD are my backup when samsung are not available, but I have had issues with one or two of them, but from memory when they are quite old. Hard drives are mechanical, they die after a while it is to be expected.
But yeah, im on a 100% record with Samsung so far *touch wood*.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
