Just watched Rocky 3 on TV, now I need to obtain Rocky 1,2,4 and Balboa (5 is an abomination and should be purged from memory!)
Epic montage.
Mikah and Luka
Had to make that shit rhyme. Next on the list, matching outfits. Fark I am gay
Sick names. Figured out how to secure baby seats in the skyline yet?
Sweet names! I like it
Morning all
Morning Mangs!
Nother busy day today
zip tie them to the roll cage?
morning everyone, looks like i'll be able to be around these parts today. Seems to be a slow day here
4 is the best by far, and yes 5 is a crime against nature.
Morning Mangs!
Mikah and Luka
+1
+11ty
Slacker. When you going to do my tyres?
That's what she said.
Stealing, stealing, stealing a car from Mcfly. Do doo doo do doo doo do, insurance fraud today.
Take my ute, please.
Successful theft is successful! :ninja:
Dow! And, once again you did not say Hi. Dissapoint :down:
HOW DID YOU DOUBLE QUOTE
I'm a mad snake.
Kind of like this :P
<3
Didn't really have time. If I've got time when I drop it back later I'll let you know!
All good mang, I didn't really have time either :P
Like this?
Nailed it.
Win :)
That sh*t is legit *tristan finger click thing*
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
