Mangs *tips hat*
Just got home from training, farking long day.
I've got to come up with a 25min presentation in work for our project and then give it on Friday morning to a bunch of directors/upper management. So far I have an outline. Sposed to be doing a dry run with the project manager tomorrow. This can either end really good or really bad lol. Wish me luck.
Injectors In
Fuel Rail In
Seems to be no fuel leaks :).
Still got fingers crossed to have the turbo by the weekend.
Meatspin for 25min?
Breif check in for me also. In Sydney this week, so I wont be around for BNR.
Nice non leaking jectors
Meatspin is for amatures.
http://www.lemonparty.org is where it's at.
P.S. HAHA
What's going on with the meet tommorow night? I've been meaning to come to one for a while now, meet people, put faces to forum profiles and the like
The only reason I would ever be in uni at 8am is for an exam. If there is a lecture before 11am at uni I wont be at it.
You'd have loved my timetable from semester 1 last year. 8am starts. every day of the week.
What made it worse was all the business students (business area's of uni are a great place to study desipite it) who go "oh are you coming in on wednesday? no? oh well see you at 11 on thursday for our lecture"
Edited by sneakey pete
What are you studying? The majority of our units are all afternoon/evening times now. Although my timetable is spread across 3 days this semester I reckon you could do it all in 1.5-2 but the timetable hates me so ahwell.
Morning Mangs.
Morning Mangs
Breif check
Tehehe
:(. I might have to come grab my ECU off you on the weekend, if my turzbro rocks up.
I'm definitely not clicking that at work...
BnR Chappel Hill, 7:30 till close.
Morning Mangs.
Mechanical Engineering (at UQ). but don't get me wrong, even the 8am starts 5 days a week semesters.... could have had them all packed into a 3 day compact timetable. The worst was the fridays on that timetable. 8am lecture and that was it for the day.
Repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive task is repetitive.
Cool story bro.
I'm Mech Eng and motoracing Second major at QUT and most of our stuff has been afternoon for the last 2 years.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
