Or charging $6,000.00 for a 33 GTR gearbox reco with standard internals? ;)
gg ERD, gg.
Shit, that's a bit of a rip off. We only charge $1500 for something like that
PWND do you honestly think I care what SAU thinks? After receiving a warning for posting in this thread this forum lost all credibility and respect. For a supposedly mature forum, to let a $90,000.00 GTT For Sale add exist, in a serious nature, is a joke.
yet you continue to post here....
You're right. That's like trying to sell a shitbox clapped out S15 for $20+ grand
i lol'd
Big thanks to Martin and Keaton helping out today!! Everything is now moved. Bit of unpacking to do, but it feels like home :thumbsup:
I'm expecting to see a thread on DIY garage door repairs lol.
I too may be moving soon, I can't be bothered moving furniture though so I'm just buying a new bed again.
Read between the lines dipshit.....
wow, i havent been on here long but i rekon you should get nominated for the tool of the year.
Always has to be one.
"rekon" has a 'c' in it mate ;)
And you nor anyone else on here doesn't know me from a bar of soap. The e-persona this account dons is nothing more than a social experiment of sorts...
Edited by GHOSTrun
  • Like 3
  • Nope 4
wow hes the spelling police.......and that bored he's doing a "social experiment" at 12:30 on a saturday night....lol. cool shirts btw...well i would have thought so when i was 12 at least (cool pics...but i'd never wear em on a shirt)
  • Nope 1
LOL at social experiment. Quit while you're behind ghosty.
The mods here are far less tolerant of dickheads than the ones that banned your sorry arse from secret drift.
And BTW, Calling pwned a dipshit is a low act. The poor little bugger has muscular dystrophy and can barely function some days.
The right thing for you to do would be to swing by his place one day and apologise in person. :thumbsup:
  • Like 1
  • Nope 2
So what you are saying is that instead of being yourself and talking to people normally you have a "e-persona". You must be bored.
These forums are all about informing and socialising, not for idiots doing "social experiments" Do us all a favour and either act normal or go away.
/rant
Good morning to the rest of you :action-smiley-069:
  • Nope 1
Oh just realised I left out the skyline one I bought too:
Still gay
Ohhhh he is a thinker, well thats ok then, feel free to continue being a douche. :rolleyes:
  • Nope 1
Morning Mangs, (not Ghosty)
Top gear live last night was fair awesome. Looks like I missed out on some fun here though.
So, boobs.
I like them.
This.
No problem, not that I helped much. At least operation fish tank was a success :).
So we aren't the only ones that think he's a tool? Wait, that was probably a 'social experiment' too...
Too right Noel! I think an apology in person is the ONLY way to make up for such a low act.
  • Nope 1
No he doesn't.
  • Like 2
  • Nope 1
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
